Technical => Engine Tech => Topic started by: turbocoupetgill on February 20, 2009, 07:31:39 PM
Title: I am stumped!! Help Please!!
Post by: turbocoupetgill on February 20, 2009, 07:31:39 PM
so i went to tighten my turbo oil feed line because it had come loose somehow. i actually never got to it cuz the intercooler is a bitch to get off( at least for me it was). now after putting everything back on it wont even boost to 15psi. I checked for a vacuum leak and i didnt here anything. I made sure all the lines were on properly and all the connections on the IC are tightened down. It is really frustrating . i want to saw the boost controller is busted but thats only because either way i turn it the boost doesnt change. If it helps the car was an automatic and still has stock computer. :mad: Please help !!!
Post by: 88turbo on February 20, 2009, 08:19:11 PM
double check your i/c connections
Post by: t3skidoo on February 20, 2009, 08:41:48 PM
you have an aftermarket boost controller?
Post by: turbocoupetgill on February 20, 2009, 09:57:39 PM
the bottom connections are hard to get to. any special way im supposed to get to them the screw for the  clamp is facing toward the shock tower and is nearly impossible to tighten at all.
yeah i have one of those cheap ebay boost controllers
