Technical => Engine Tech => Topic started by: flipnbird on August 14, 2008, 06:48:02 AM
Title: ###!**** fuel pump.....running again !!!
Post by: flipnbird on August 14, 2008, 06:48:02 AM
awhile back I was having problems with my car,
http://www.foxtbirdcougarforums.com/showthread.php?t=20045
on the above post my last post was that she was fixed,,,,she was for about a week then she started going south on me again. So after reading all the posts i decided to throw in a new pump again. She was FIXED again ...........for about a week, what the he!!. I did some searching and found this thread,,
http://www.foxtbirdcougarforums.com/...86&postcount=3
I done all the above tests and i guess i will need another pump, there is no buzzing, priming sound what so ever!!!! :punchballs:
The question is...BUT WHY???? what could be making these pumps die so fast?  Walbro at that!!  It's not like they are THAT difficult to put in.............if anyone has an answer please advise.
Thanks, Joe
Post by: Chuck W on August 14, 2008, 07:06:42 AM
It might not be a real Walbro.
There are some knock-offs floating around that are IDENTICAL to the Walbro ones, down to the stampings on the cases.  The thing is, they aren't Walbros...
Post by: speeddemon31176 on August 14, 2008, 08:03:29 AM
Not to play devils' advocate but what about the possibility of a short in the circuit or a faulty/intermittent ground issue putting strain on the fuel pump motor. Could be causing it to fail prematurely. Just a thought. Not a direct answer to your question. Just thought it might be something to check out after three fuel pumps. If they are real Walbro pumps I would start looking for other causes to your problem. Just me .02.
Post by: Chuck W on August 14, 2008, 08:34:56 AM
If the pump you bought was not advertised as a REAL Walbro pump (i.e. it was listed as a "255lph" pump or the like, and it was CHEAP...it's not a Walbro.
As an example
http://forums.turbobricks.com/showthread.php?t=140796&highlight=walbro
I also second the wiring issue, perhaps check your fuses.  I just ran through a similar issue on my Volvo...a bad/old/corroded fuse was causing the intank to cut out.
Post by: TurboCoupe50 on August 14, 2008, 09:35:52 AM
Quote from: speeddemon31176;231915
A short in the wiring would keep voltage from flowing to the pump. won't run, but won't damage it either... A poor connection/ground that's high resistance, may damage motor due to it not receiving enough voltage to run... Since the pump is submerged, the gas keeps it cool(good reason to not run the tank low), and I actually doubt a bad connection anywhere but on the pump it's self damaging it...
A friend showed me a S-10 pump he changed, that the electrical connector on it was a charred lump... Said it still ran but the truck had weak fuel pressure(was drivable as long as you didn't give it more than quarter throttle) ... Customer told him he'd been having problems for over a year and no other shop had been able to fix it... Amazing thing to me is it didn't catch on fire...
I'll never buy another Carter, the one I but in my Bird in '99 died in a little over a year, my real Walbro is still just fine...
Post by: speeddemon31176 on August 14, 2008, 11:56:17 AM
A short in the wiring would keep it from running if it was an open short. I was thinking more along the lines of a hot short to ground where the pump was still getting voltage but not enough to operate properly. I have seen it before in particular on the last generation of Chevy Caprices where the green(power feed) wire runs under the back seat on those cars and gets pinched from passengers and starts a short to ground but not enough to stop it from working. I spent several days tracking down that problem but when I found it I was able to stop replacing pumps(they weren't the problem). The feed wire was. Just a thought. I am not as familiar with these cars yet as I would like to be or as most of you are but I am working on it.
Post by: speeddemon31176 on August 14, 2008, 12:00:12 PM
Try bench testing one of your pumps that you pulled out. Apply power and ground to the appropriate terminals and see if it runs. A few seconds without it in the tank drawing fuel won't hurt it and since you said they weren't running at all this would tell you if it is the pump or wiring.
Post by: flipnbird on August 14, 2008, 01:12:22 PM
Quote from: speeddemon31176;231935
I did just that yesterday with the one before the one that is in it now and it was dead,dead!!! The one that is in it now ran fine for the 3-4 times that i drove the car then 2 days after she was parked i went out to start it, she fired right up then died after 15 seconds or so, started her back up and it ran for another 10 seconds then died, started her right back up and ran for 2 seconds and died after that i couldn't get her to start and the pump wouldn't even prime.
  I checked and checked about everything from the link in my first post, even put in a new relay(which you CAN here it click when the key is switched to on, had my son lay in the trunk to listen.
Tonight (if i get the chance--2 kids) i am going to try and drop the tank and see if i have power at the pump, check for any bad/broken/worn wires and such.
Thanks for all the replys, I haven' t really got to enjoy my ride for about a month1/2 now
Post by: speeddemon31176 on August 14, 2008, 02:04:15 PM
I hear ya. I know all about the kids thing. I had to take the day off today cause one of mine are sick(read contagious). It's not too bad since I run my own company. If you were closer I would come and help you figure it out but NC is just a bit too far away for me. I know all about not getting to drive it too. I bought the car with it needing a head gasket. We took the head off had it surfaced and reinstalled it only to find out that I should have primed the oil system before I started it. I had changed the oil just to be safe and bye bye went the turbo in a matter of seconds. We tried to rebuild it but somehow got the wrong bushings in it and that didn't work. I just put it back together yesterday with a new center section. I am staring at the new oil lines from Stinger right now. Can't wait to put em in. Anyone know what the extra port is for on the feed line fitting?
Post by: flipnbird on August 15, 2008, 05:27:10 AM
Kids are great, fun, but sometimes there is just not enough time to yourself!!!
What kind of company do you own/run?? When I get this tank down shouldn't i just be able to pull the plug off the top of the pump and probe them two wires to see if i have juce? (while key is on) or will i only have juice for the 2-3 seconds of prime time?
Thanks guys,,,,,,,,,,,,,
Post by: jcassity on August 16, 2008, 01:05:49 AM
Quote from: Chuck W;231917
No such animal chuck.
THere is a fuse link but no fuse associated to the fuel pump.
Post by: jcassity on August 16, 2008, 01:17:34 AM
Quote from: speeddemon31176;231934
please stop,, I cant believe your posting up such polluted information.  You are the only one who knows what you mean by an "open short".  IT does little to help people with problems when people pipe up with trivial diagnostics like this.
You need to know a little bit about the circuit layout or even what everyone else is talking about before you lay out the advice.
Another thing, why would chevy use a green color as a primary for such a load bearing device.
sorry to sound rude.,,
locate yellow wire up at starter solenoid (feed to fuel pump relay)
locate fuel pump relay (upper rt side of trunk)
locate inertia switch (typically located just on the other side of your license plate area in the trunk)
  Inertia switch gets power from a splice and then back to the output of the eec relay via the black/yellow wire.
Loate EEC relay (upper right hand side of instrument panel)
Identify the wiring plugged into the fuel pump relay
    yellow (from solenoid to input relay contact)
    Pink / black (from relay output contact to fuel pump input)
        the fuel pump ground is obtained by the orange wire.
    Red wire (relay coil input from inertia switch)
    tan/light green wire (this wire is the key, ground supply to the fuel pump relay)
        the tan light green wire is supplied a ground from the eec alone and nothing else.
Note the feel of warmth or not on the fuel pump relay after the car has been running for a while.
How it works,,,,,,,,,,,
key is turned on, the eec relay contacts close and power is delivered to the inertia switch and the EEC.
The eec now sees power.
the inertia switch is passive (a little ball sits in a seat and pretty much shorts the switch closed)
power comes out the inertia switch and travels through the coil of the fuel pump relay.
the eec knows it has power so it provides a ground to the fuel pump relay tan/light green.
magnetism takes over and the relay contacts are sucked together.
Now the yellow wire from your starter relay delivers power up through the fuel pump relay and out to the fuel pump.
the fuel pump sees power and it gets a ground from chassis.
I time delay kicks in and if the car is not running , in 3-5 sec, the fuel pump will stop running.
TO BYPASS THE TIME DELAY>>>for trouble shooting reasons.....................
locate your eec self test connector up near the driver side strut tower.
have your key off
ground the TAN light green wire  (does this color sound familiar?)turn on your key
now your fuel pump will run full time without the engine running.
Turn your radio on to Any AM station that has very little static (try to not be in a garage with flourecent lighting)
wiggle the wire harness along the fuel tank, the inertia switch, the fuel pump relay, and possibly even the eec relay.
Listen for pops and crackle as you wiggle/pull test wiring.  If you hear pops in an isolated area, there is your high resistance problem.
turn radio off
mesure voltage up at the starer solenoid (yellow wire)
measure the voltage at the yellow wire back at the fuel pump relay (input power)
measure power at the red wire fuel pump relay coil input (from inertia switch)
measure the voltage at the pink/black wire (relay output to fuel pump in)
measure power on the input to the inertia switch (red)
measure power on the output of the inertia switch (red)
make sure no power exists on the tan / light greed wire., measure for resitance from the tan/light green to frame ground
document your above voltage readings and let us know what you find.
your known good or "standard" voltage reading will be what was documented at the yellow wire at the starter relay.
Any voltage lower by 1.5v or more should be the focus of your troubleshooting.
your car should not be running during any of these tests.
see attached wiring diagram
Post by: Cougar5.0 on August 16, 2008, 01:38:21 AM
Doesn't everyone know what an "open short" is? :hick:
Actually, I catch the drift of what he was trying to say after reading more - you might want to call it a partial short or intermittent short or "high leakage" current to ground. Anyway, if the pump voltage measures low, then you know something's up. If the voltage is intermittent, something's up. Sounds like you'll know more with the tank on the ground and a voltage meter.
Post by: jcassity on August 16, 2008, 02:06:15 AM
see edit,, took about an hour but that should help
I took notes on the walboro pump info that, thats intersting and appears to be common just like chuck said.
Post by: ipsd on August 16, 2008, 01:11:31 PM
The relay controls the ground side. When I did testing in my car 84 T/c. the signal coming form the EEC to the relay was a ground circuit. So the EEC grounds the relay to make it switch.  So as my car had a hacked relay they spliced the wires coming from the pump to the relay directly to the wire from the EEC. So when the EEC send a GND Signal the fuel pumps turn on. I haven't dug up all my parts to fix it yet. But this is what I found on my car.
Post by: speeddemon31176 on August 16, 2008, 09:16:19 PM
I am an electrical contractor. You should be able to probe the wires for power for as long as needed. The only way you wouldn't have power is if the pump were connected and it built up pressure IIRC.
Post by: speeddemon31176 on August 16, 2008, 09:25:28 PM
Well obviously I should have read page two before I posted. I am sure you didn't mean to sound rude. You obviously meant to insult me. I was simply trying to help someone with a problem and you consider any advice I gave him polluted. It was not polluted. It is a very common term that is used all the time. I promise not to help anymore. Sorry my advice was useless. As far as chevy not using the wire color I described, call the dealer near you and see what they say. This is the exact reason I don't work on vehicles as a profession anymore. You try to do the right thing and help someone out and of course there would be someone lying in wait to come along and flame you cause they don't like what you have to say. Well enough of soapboxing.
Post by: flipnbird on August 16, 2008, 10:01:54 PM
@speedemon(don't give up on me, I appreciate any help)...allright, my son and I checked the power going to the pump(right at the pump plug), checked with the old trusty 12v light thingy(got power for the first 2-3 sec, prime time).
  We then checked the voltage (key on) with a volt meter and got a .30 reading?? is this right?? we checked all the wires going to the pump and they all LOOK in great shape, they aren't cracked, broke, or even fragile at all, the underneath is very clean. I did notice when we took the pump out that the plug going right into the pump itself wasn't all the way locked, pushed it in and still nothing. Took the pump out and bench tested and she was DEAD!!
  @jcassity,,,,I will try all your info tomorrow(thanks for your help, you are the electro man!!), I did try probing the pump ralay(yellow wire) the other day with a 12v light(watchamacallit)and there was consant power, but i didn't check the voltage, I will try this tomorrow also(should it be 12????volts??)
  It just seems funny that i never had this problem untill my son and I put in the (1st) new pump, the tank has never been down before this(as far as i know).
Thanks again guys for all the help so far, i REALLY want to drive this thing again,like NOW!!!!!
Post by: speeddemon31176 on August 16, 2008, 10:30:20 PM
Flipnbird, When you tested the leads at the plug. was that with a digital multimeter(voltmeter)? What was the meter set to? Was it set to voltage or was it on another seting such as ohms? If you had your meter set to DC(direct current) voltage and you received a reading of 0.30 volts and the meter was set to (as the meters that I use) 20 volt setting then NO that would be a bad voltage reading. If your meter also has a 200 volt DC setting then that would mean on the 20 volt DC setting(if your meter has that) it would have read 3.0 volts DC. This would still indicate to ME that you have a wiring issue. I could be completely "wrong" about this though. If you want to, I will PM you with my cell number and we could discuss this more in depth without any confusion in terms stemming from vocabulary discrepencies. Let me know.
Post by: jcassity on August 17, 2008, 12:20:07 AM
Quote from: flipnbird;232300
you forgot to do one thing,, you forgot to make the pump run full time and thats why you got no power or .3v for a reading.  the ground to the fuel pump relay was removed by the eec at 3-5sec.
now go back with a jumper wire and do the full time test.  once that is done, you can test.
as for the power and your asking if it should be 12v.....?
Not once did i mention 12 volts.  I said that your reading on the yellow wire at the starter solenoid will be your "standard" or your reference voltage.
speeddemon-
he said he checked with a volt meter,, and judging from he exact reference to a .30v its highly unlikely anyone would be able to interpert an buttstuffog meter reading to that level of exactness unless like you said, he was set on the DCVx1 scale.
sorry i pissed you off but terminology means the difference between good enough and dead on.  I doubt you will find anyone in the electrical industry (like me) using odd wording like that.  If you worked on one of my projects and told me you had an open short, i would know right off the bat my problems were bigger than i thought.  I was going to cut you slack until you said you were an electrical contractor,, tighten up and learn your jargin, its an important characteristic of the service you represent.  Use that wireing diagram i posted and help this guy out,, its a pretty easy circuit to follow.  You cant see on the diagram but the inertia switch gets its power directly from a splice which originates from eec relay.
Post by: jcassity on August 17, 2008, 12:39:50 AM
ok,, i know you have a problem and we are trying to help but when you reply back with missing detail, its hard to understand.  I make zero assumptions and per your answer:
"We then checked the voltage (key on) with a volt meter and got a .30 reading?? is this right?? "
Where did you check for voltage?
so,, id think the best way to answer all the items listed is to print out my post and ink in your answer.
next, come back on here, quote my post and insert your answers.  that will help the best.
Post by: speeddemon31176 on August 17, 2008, 12:48:01 AM
I am not trying to start a fight with anyone. I would like to help this guy out with his problem. I didn't mean to get nasty with you but I am having one hell of a time with this car that I bought from a "friend". I am sure you know what I mean. As far as my terminology is concerned, my proffessor at Penn State used those terms with us about ten years ago. Since aparently he used off the wall terms what would the correct nomenclature of those conditions be? I am being serious when I ask you this. You are never to old to learn something new. I have never had anyone before comment on my use of "open" and "hot" short. Actually now that I think of it everyone that I have worked with in this area uses those terms. Maybe it is just the locale. Who knows. Anyhow back to the problem at hand. Lets get this guys car running again.
Post by: speeddemon31176 on August 17, 2008, 12:59:44 AM
Jcassity, I was asking him about what his meter was set to since he coud be using some off the wall brand(Harbor Freight) meter. I have seen those meters used by kids at Circuit City and such and noticed that they had very weird settings on them. Not standardized at all. I use fluke meters and have even found them to be off before. I don't know why they were and won't venture a guess either. I was trying to simplify the settings for him as well since I am assuming(I know) that since he referred to a test light as a "whatchamacalit" that he is not adept to doing electrical repairs.  Lets get him up and running again shall we.
Post by: jcassity on August 17, 2008, 01:25:11 AM
oh im dead sure flipnbird knows what he's doing.  hes been around these cars for a long time.  he knows darn well im an ahole sometimes when details are needed.
to answer your question, an "open" and a "short" can not occupy the space in time.  Its either open or short or an intermittant open but never an "open short"
There are leaky circuits that happen but those are special instances and rarely do they occure where a breaker or fuse is not blown in a reasonable time.
It grips my ass everytime i hear someone say,, "i dont have power,, there must be short somewhere".  I say,, "no, you must have an open somewhere if the fuse/breaker is still good or set"
people need to understand that the word "short" is the last thing you want and typically starts fires.
Post by: flipnbird on August 17, 2008, 12:11:46 PM
Quote from: jcassity;232333
Yes I did forget to do this and I will try again
I gotcha on this one and I will also check this reading and go from there. which i take it that whatever that reading is(at the starter selonoid) my readings at the pump shoul read the same??
speeddemon-
my meter is an older Tenma digital meter and I had it set on volt/DC when I took my reading which was right at the plug that hooks into the pump. I am not really top notch when it comes to what to set my meter on and reading these meters but i will give it my best when i have you electrical gurus to show me.
Thanks guys
Post by: flipnbird on August 17, 2008, 12:12:02 PM
sorry,,, double post
Post by: flipnbird on August 17, 2008, 12:16:26 PM
next, come back on here, quote my post and insert your answers.  that will help the best.[/QUOTE]
I am printing these out as we speak,,,,Thanks
Post by: jcassity on August 17, 2008, 02:03:32 PM
Quote from: flipnbird;232378
yes, but note your voltage may drop a little due to the volage drop across the wiring which is normal.  Look closer at any reading 1.5v less than your standard.
Post by: flipnbird on August 17, 2008, 07:01:41 PM
@jcassitty- got all my readings, as per your earlier post-----------
voltage-starter selonoid=12.3
voltage-yellow wire at fuel pump relay=11.93
voltage- red wire fuel pump relay input(from inertia switch)=11.93
voltage- pink/black wire(relay output to fuel pump in)=11.93
voltage- input to the inertia switch(red)=11.89
voltage- output of the inertia switch(red)=11.89
I also checked the voltage at the plug that goes into the pump=11.93
make sure no power exists on the tan/light green wire,,,,where(pump relay?, at the self test/ without ground?/or with?)---- also how do i check for resistance from the tan/light green to frame?(what shoud i set my meter on for a resistance reading)??
Thanks so much for all the help, Joe
Post by: jcassity on August 17, 2008, 10:09:03 PM
Quote from: flipnbird;232425
actually , the more i think about it the more i realize my fingers got ahead of my brain on that one.  If you check for power on the tan light green wire to ground, your just going to run your pump full time.  its the same point electrically as the eec self test conn where you pull codes.
So if you pulled your readings with the tan light green grounded out, it appears all is well with power delivery of your fuel pump circuit.
Did the pump run with the Key on and the TAN/ LightGreen wire grounded ?
You can ground this wire back at the fuel pump relay also just by probing it with a stick pin and gator clip it to chassis ground or........ ground it up at the eec self test conn.
If your are able to get the pump to run with the tan light green grounded at the fuel pump relay but not at the eec self test connector, then the wire is broken either up at the eec self test path or more likely the path leading up to the EEC.
Your first complaint was you could not hear the pump prime at all,, did you hear it run?
Post by: flipnbird on August 18, 2008, 05:41:04 AM
Quote from: jcassity;232457
 NO i didn't here my pump run because i no it is dead (bench tested) and my new one won't be here till mid week, at least i know for now all my wiring is good to go, Thanks for ALL your help !!!,,,,,, YOU ARE THE MAN!!!!
I will let you know iff she starts right up when i get my new pump in. In the mean time my son is cleaning/painting like he!! up under my car and doing a  good job at that!!
Thanks again, Joe :bowdown:
Post by: jcassity on August 18, 2008, 10:44:16 PM
A good word of advice,,,
ask for a fuel pump from the 3.8 supercharged cougar.
they go right in the stock shock absorber rubber boot and they do about 90Lph vs your cars stock 60Lph.,, plus they are only about 45 bux.
You will get only the pump btw, nothing else.
Post by: flipnbird on August 29, 2008, 11:38:51 AM
Good news (so far),, she is up and running and running good !! (knock on wood)
Thanks again guys
