General => Lounge => Topic started by: vinnietbird on February 03, 2008, 07:27:41 PM
Title: It has begun.....UPDATE..
Post by: vinnietbird on February 03, 2008, 07:27:41 PM
I'm installing the E303 and new heads tomorrow,I started this evening by pulling the fan,upper intake,valve covers,rockers,and harness from the engine.Tomorrow morning,the rest will come off and the new parts go on.I'll grab a couple of in progress pics in the a.m. Wish me luck.
Post by: cougar1car on February 03, 2008, 07:31:58 PM
Good luck Vinnie I know how much of a bitch it was puittin my expedition engine back together but I did it and it runs once again...
Post by: mercury-man on February 03, 2008, 08:05:23 PM
Luck, Vinnie and by the way this project of yours sounds alot like work on your day off. LOL
Post by: SLEEPER T-BIRD 87 on February 03, 2008, 09:18:26 PM
Quote from: vinnietbird;201917
:burnout:
Post by: vinnietbird on February 03, 2008, 09:58:44 PM
Quote from: SLEEPER T-BIRD 87;201929
:burnout:
:burnout: .........................TRUE DAT !!!
If I get started around 9:00,I should be finished before lunch.I'll be taking my time and enjoying it all.It's supposed to be around 79 degrees according to our local news.Couldn't ask for a better day.I am a little anxious.I'll try to get a burnout shot if I can get my little man to stand on the curb and shoot the pic.You guys will be the first to know.
Post by: daminc on February 03, 2008, 10:13:46 PM
We'll be waiting for those pics. I'd go for the video myself
Post by: vinnietbird on February 04, 2008, 12:45:03 AM
I may be able to do that.I'll try.
Post by: vinnietbird on February 04, 2008, 06:52:29 PM
Well,not finished yet.Had a bad plumbing issue here at home.More updates on the car tomorrow.
Post by: vinnietbird on February 05, 2008, 04:31:55 PM
O.K.,the E303 and new ported E-7 heads are on and I'm finished.I am having a crazy idle issue,but I'll have that taken care of.I drove the car down the street with the tires blazing.When I stopped,it died.I started the car up again,drove it home,and called a mechanic I know.He's going to come over tonight around 8:00 and check everything and set the timing for me (I STILL haven't bought a new timing light yet).He's going to take care of that in trade for the heads I took off of the Sport.
  Now,for those who didn't believe,an E303 and ported E-7 heads DO work with my flat top pistons,no PTV issues.There's the update for now.
Post by: Kitz Kat on February 05, 2008, 05:34:12 PM
HE HE HE,whats up with idle vinney?You may need to boost a little more rpm.I had to do 850.
Post by: vinnietbird on February 05, 2008, 05:41:35 PM
I had thought that,and so did the mechanic that's coming over.No issues other than that.WOO-HOO !!!!!!!!!!!!!!
Post by: Kitz Kat on February 05, 2008, 05:58:42 PM
You didn't make the valves to tight this time did you? That will
make it idle funky.
Post by: vinnietbird on February 05, 2008, 07:40:52 PM
I don't think that's an issue.The last time,the heads were milled and I didn't take that into consideration,so,when I tightened the rockers,they were pushing the rods to far into the lifter and the lifter couldn't open.I hope it's just an idle issue,meaning,needs more.He's also going to time it for me.Now I have another issue,my differential (locker with 3.55's) is soing the "one wheel peel" now.The left side doesn't bite.Luckily,I bought another one last Friday.I'll get it in eventually.No hurry right now.The bottom line,the cam and heads are in,and the cam did work.Thanks Kitz.
Post by: Kitz Kat on February 05, 2008, 08:03:47 PM
Don't thank me you proved it!,When I have time I,m only going to try the 1.7 lifters!,
Post by: Kitz Kat on February 05, 2008, 08:11:17 PM
Your rear,you wont till you check it,When you get to the new one you got, put a new clutch kit in it.Took mine apart that I got ,from someone on here,I just replaced stuff that didn't need to be.Got the old stuff if you want it.
Post by: vinnietbird on February 05, 2008, 08:12:58 PM
If I can use the E-7's and the E303,the 1.7's should be a breeze.It feels good to finally be done with that part of the Sport's build.Now,I can concentrate on getting my a/c pieces (trying to re-install the system from scratch),and the 5 speed swapped.I have the pedals.The tranny and bell housing are in route.I'll buy the clutch,cable,etc. over time.I also need to have the Sport painted as well.Probably before the 5 speed.I'm really getting tired of seeing the red,blue,gold and primer.LOL.
Post by: vinnietbird on February 05, 2008, 08:14:21 PM
How hard is it to do that?I have NEVER messed with the gears or clutches or any of that.Swapping axles and bearings are about it.
Post by: Kitz Kat on February 05, 2008, 09:14:44 PM
Easy, than what your doin to the engine.
You goy my # call me.
Post by: TurboCoupe50 on February 05, 2008, 09:24:10 PM
Just don't over rev it and float the valves... I bettin' you'll have pistons kissing valves...
Figure it's going to have to idle at least 800-900 RPMs...
Post by: Kitz Kat on February 05, 2008, 09:33:51 PM
Quote from: TurboCoupe50;202382
Funny on the quote I see kissin valves,not in the message.
He did ptv the cylinders though I don't know how close they were?
Post by: vinnietbird on February 05, 2008, 09:34:37 PM
What are you calling "over revving"?I probably won't hardly ever see 4500 or 5000 rpms.90% of the Sports life is just going to work about a mile away,picking up the boy from school and going home.RARELY is there a little "stoplight action".
Post by: Kitz Kat on February 05, 2008, 09:35:16 PM
I must of missed that!
Post by: vinnietbird on February 05, 2008, 09:35:30 PM
Oh,Kitz,PM me a little info on swapping the clutches in the 8.8.Just to give me an idea of what I'll be doing.
Post by: Kitz Kat on February 05, 2008, 09:36:34 PM
Vinnie you do have upgraded springs?
Post by: vinnietbird on February 05, 2008, 09:37:19 PM
Yes,he added new springs when he did the valve job and porting.
Post by: Kitz Kat on February 05, 2008, 09:37:37 PM
No problem, Vinnie
Post by: daboss351 on February 05, 2008, 09:38:36 PM
Awesome vin!!
Did u get that 20 i sent to you?
Post by: vinnietbird on February 05, 2008, 09:41:31 PM
I did get it,Mason.My opologies for not letting you know.I've had my head in the clouds with all that's been going on around here lately.Thanks.
Post by: thunderjet302 on February 05, 2008, 09:46:47 PM
Hell with the mild cam in mine (@.050 210I/215E, lift .533I/.533E) I have to have it idle at 1050 rpms in park and about 800 rpms in drive when hot or it gets all surgy and stalls when I shift from drive to reverse.
Nice to know its done. Now fix the rear so you can do this :burnout:
Post by: daboss351 on February 05, 2008, 09:51:35 PM
Quote from: vinnietbird;202397
Np just wanted to make sure its all set!
Post by: vinnietbird on February 05, 2008, 09:57:29 PM
I'm going to rebuild the 8.8 I bought last week and install it later on down the road.No hurry right now.It's too cold outside again.Yesterday it was 79 degrees,today,40.Oklahoma weather is crazy.
Post by: thunderjet302 on February 05, 2008, 10:11:32 PM
Quote from: vinnietbird;202408
40* is warm. We're getting about a foot of snow tonight.........
Post by: vinnietbird on February 06, 2008, 12:26:17 AM
Let me elaborate.40 degrees,raining,and windy.The temp is the easy part.LOL.I'm not going to complain much,compared to the northern folks,we don't have a winter time.
On another note,the car is now idling well.The cam has a slight lope to it.I expected that.Kitz warned me.Really good power .I could really feel the difference with the E303 and the heads.Now,I can concentrate on some much needed paint prep.It's nice to have this finished.I drove the car a short while ago,and it easily breaks the tires loose and has the car going down the street a little sideways.A little squirrely,I love it.Decent idle,about 850 right now.I'm pretty happy.
Post by: CougarSE on February 06, 2008, 01:22:16 AM
I'm surprised you haven't come across a set of explorer heads for your car.  I picked a set up last fall.
Post by: vinnietbird on February 06, 2008, 09:13:57 AM
I did have a set.I was told that they wouldn't work with my flat top pistons.So,I sold them on Ebay.That was then,this is now.I may try a pair when I find a set.If an Explorer comes in aat my favorite yard,he said he'd sell me the pair for $150.00.I'll pay that.I'm pretty happy with the engine right now.It's running really strong and feeling good.
Post by: V8Demon on February 06, 2008, 09:22:31 AM
Quote:
Figure it's going to have to idle at least 800-900 RPMs... Hell with the mild cam in mine (@.050 210I/215E, lift .533I/.533E) I have to have it idle at 1050 rpms in park and about 800 rpms in drive when hot or it gets all surgy and stalls when I shift from drive to reverse.
I must be doing something wrong.....Idle is 900 in park 750 in drive:hick:
You'll most likely have to bump yours up a bit with the E cam, Vin....
Post by: Bob on February 06, 2008, 09:23:45 AM
nice, goodjob.. lets see a video or some pics something... I need some motivation to get my project moving
Post by: vinnietbird on February 06, 2008, 09:27:35 AM
Mine is about 900 rpms in park.It has a little "rumpity,rumpity" lope to it,yet maintains a good idle.I'm going to try and have a burnout shot today.I have to find someone to grab a pic for me.
Post by: Bob on February 06, 2008, 10:05:10 AM
Quote from: vinnietbird;202489
cool... get a video up!
Post by: vinnietbird on February 06, 2008, 10:17:01 AM
I've never done a video with this camara.I'll try my best.
