Technical => Suspension/Steering => Topic started by: fordguy on May 24, 2007, 09:54:50 AM
Title: quad shocks
Post by: fordguy on May 24, 2007, 09:54:50 AM
are the mustang and tbird quad shocks the same? i know the brackets mount different. i have a pair from a tc but need to know if they will work on the stang.
Title: quad shocks
Post by: EricCoolCats on May 24, 2007, 10:11:38 AM
Yep, the axle dampers are the same between cars. In fact, a lot of parts stores will only list the dampers for Mustangs, but they are identical to those used on the T-Bird/Cougar.
Title: quad shocks
Post by: SLEEPER T-BIRD 87 on May 24, 2007, 08:08:56 PM
Quote from: EricCoolCats;149349
the thunderbird/cougar quads are longer. then the mustang units.
ive swapped bird ones into the stang with no binding but the stang units maybe a hair short for a stock height cougar bird
Title: quad shocks
Post by: fordguy on May 25, 2007, 09:01:25 AM
thanks guys
Title: quad shocks
Post by: 1BadBird on May 25, 2007, 09:35:28 AM
That's true sleeper. When I installed my IRS setup, the rear brackets were supposed to line up with the quad shock bracket holes. They didn't come close. When the mustang guys did their swaps, they could reuse those holes.
Title: quad shocks
Post by: EricCoolCats on May 25, 2007, 09:55:05 AM
That's due to the rear frame rails being different, and the brackets attached to them, AND the distance between the mounting brackes on the rear axles themselves...and all of those have nothing to do with the actual quad shocks. The quads are the same between the cars. You cannot buy a Cougar- or T-Bird-specific quad anymore. They're only listed for Mustangs. And if you do find a store that lists them for our cars (which is a miracle), that shock will cross-reference to a Mustang.
The quad shocks are not under tension like a normal shock. You can push or pull on them to whatever length you need, and they just stay. If binding is an issue...flip the shock around. That usually solves the problem.
Title: quad shocks
Post by: tommym on May 25, 2007, 09:06:35 PM
I installed Monroe gas matic quad shocks, (32242), on my 87 TC with no problems.
Title: quad shocks
Post by: chri85tc on May 25, 2007, 10:44:15 PM
I got a set of KYB gas for my dampers, listed for an 85 T-Bird.
