Technical => Engine Tech => Topic started by: 88turbo on May 14, 2007, 10:56:01 PM
Title: boost fluctuation?
Post by: 88turbo on May 14, 2007, 10:56:01 PM
when accelerating to highway speed my boost fluctuates from 18psi to 10 back to 18 and so on.  I am running an adjustable actuator only.  do I need to adjust it alittle to hold the wastegate closed more tightly?
Post by: dudeman351 on May 15, 2007, 07:06:47 AM
check you're hoses for any kinks. mine did that had to reroute the hoses.
Post by: Tbird232ci on May 15, 2007, 04:59:41 PM
Tighten it more tightly, and use a manual boost controller.
Post by: 88turbo on May 15, 2007, 05:53:41 PM
I'll see what I can do with it when it cools down a bit more.  will keep you posted and thanks again shawn
