what is the torque spec for the bolts from the upper intake to the lower? i read 12-18 ft-lbs on one website, im just double checking because i dont feel like screwing up.
p.s. if everything goes right ill have some things to add do my signature about my car, wish me luck, i usually dont have much
I nearly stripped a hole on my brand new Cobra intake trying to go 200 in/lbs (16 ft/lbs). I was going real slow (because it seemed like too much torque) and I felt the threads start to give so I stopped. Next time I have to take my upper off I'll be repairing that hole:mad:
I'd go 12 (144 in/lbs) and use blue loctite on the threads.
I have always just snugged them down without any issues.I've had my intake off a dozen or more times at least.
I just snug 'em down too. Same with valve cover bolts. Intake to head than yea use the torque settings. It's really easy to strip the upper to lower holes since they're aluminium.
18-22 foot pounds. Start at the center, criss-cross your way out to the ends. start'em off around 16 footpounds each, then go back and keep bumpin' up 'till you hit 20 or so.-Info right out of ford shop manual.
sorry, i thought i told everyone. i've had the upper on for about a month now. i torqued them to 14 ft/lbs. the threads didnt feel like they were stripping, so thats good. thanks for all your help.
