Hi everyone i was just wondering wich fuel pump should i buy for my stock 3.8 im aiming for a bbk one they seem reliable hom much lph i need?
Unless you're going to swap to a V8, anything above stock is wasted money...
Dont the v6's and stock S.O. 8 cyl's have the same fuel pump?
i put a 255lph in the gas tank and a 50gph inline pump to . i felt a big difference compared to stock when flooring it in my modified v6.
a 255L / hr pump is pushing about 58US gal/hr
the additional in line pump would be a restriction in my opinion.
3.8 & SO 5.0 use a 60lph pump, HOs use a 88 & the Super Coupes use a 95lph...
I doubt the stock fuel line fittings will even flow 255lph, I have a 190lph in mine...
http://www.bbkperformance.com/products/fuel-system-components/fuel-pumps/86-95-mustang-in-line-fuel-pump-system.html -http://www.bbkperformance.com/products/fuel-system-components/fuel-pumps/
the inline is a direct fit like the stock inline pumps. also the 255lph work great with the stock fuel lines till i upgrade the fuel lines.
My fuel lines work fine too,
but I didn't say fuel lines, I said fittings...
Have you ever looked at the opening in the male connectors??? May be 1/8"...
do i have to change the inline do i even i have one? and if so can i just change the in the tank fuel pump
