hi guys i would like to know whats the difference between thewindow channel felt run and the door glass window run they have diffenrent part numbers and im having trouble indetifying which is which btw i have vent windows
thanx alot guys
Where did you find new seals? If you look at the top of this section there is a write up from a guy on what he was able to use. I think its in assembly/dis-assebly section. I too have vent windows and I ended up finding seals from a tempo for the window channel and then I bought the dew-wipes from JC Whitney. Although the tempo ones work and look 100% better I might be interested in correct ones if you have found a supplier( I am sure others on here would also)
