Topic: Sub-frame connectors (Read 3001 times) previous topic - next topic
'83 Cougar LS 5.0, has anyone added subframe connectors to their car?  If you did, how did you re-route the fuel lines that snake back and forth in the factory-severed frame rail space??  Thanks in advance.
Yup.
Didn't do anything with the fuel lines on mine, just wrapped a wet towel around them while I was welding.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
i think he meant the the fuel lines were in the way of the connectors. i know the rear brake line is in the way, near the firewall.
1979 Ford Fairmont
[/B]
Mine wasn't, at least not that I recall :dunno:
Garrett H.
Exhaust sound clip
Another clip
the earlier cars use a different fuel pump/filter/line setup than our cars.
It's Gumby's fault.
That happen to be right in the way on my 83 Cougar LS 5.0...
On mine I didn't have any issues.  I pulled the lines down from the front subframe while I did the welding and made sure they were clear on the rear SF when I welded back there.  The lines were then reinstalled in their original location after the welds cooled.  Did it on both '83's and the '84.
Long live the 4-eyes!  - '83 Tbird Turbo
Thanks, I just have to do a bit of re-routing.
What subframe connectors did you use, mustang ones? Or did you make your own.  I need to put some in myself.
mustang ones dont match the floor pan of the bird/cat.
nice thing is though, if you are goin bottom mount you can jus use straight box tube w/no breaks in it.
Quote from: Red Spar;137578
there are one or two companies out there that still have tbird sfc.  I can't remember the names though.  I think MOtion Dynamics may have some, even MM IIRC.
Ryan[/i][/COLOR]
1986 2R[/b] SVO
1984 T-Bird 5.0 (In Hibernation since 10/96)
40bob sells some on his website.
But, they're really just straight pieces of rectangular box tubing with caps welded on the ends (they're cheap though, $65/pair and they come with reinforcement plates).
Also good luck finding any with seat braces as I don't believe anyone actually sells them with seat braces.
Garrett H.
Exhaust sound clip
Another clip
Quote from: Red_LX;137803
Mine have got seat braces :D They were from the last few KB ones that Chuck sold here awhile ago. Unfortunately the only thing mine are bracing right now are the garage wall - still haven't gotten around to installing 'em. Might do that this week, now that the TC rear is in...
I have made a set using sqaure tubing and we didn't do anything with the fuel lines cuz my friend had a fuel cell in his car but I am working on designing a set for my car and I don't have a fuel sell.  I will try to get a picture of the ones I made for my friend. I am a welder/fabricator and I would have to say that it is a little difficult seeing that the subframe is galvanized.  But I will see if I can get something for ya.
Well, I have seat braces too, I got what I believe was Chuck's last set of braces.
However, I figure it probably wouldn't be THAT hard to make your own seat braces. Would just require a little extra R&D work under the car.
Garrett H.
Exhaust sound clip
Another clip
